stem removal on lady,s wrist watch "Click" to Login or Register
posted March 17, 2004 12:51
Just a general question, i do not work much on lady,s quartz watches, i want to remove a stem to clean the dial and crystal and case.I have seen on some small mechanical movements a pin you push that disconnects rhe stem.
Any thoughts on this?
Kevin "Veritas" West
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
Watch Repair Expert
posted March 17, 2004 16:54
Most modern quartz watches have a little lever that's supposed to be depressed in order to release the stem. The lever should be somewhere near where the stem enters the movement, and it should have a "dimple" in the end of it, which is intended to prevent the point of a sharp instrument from slipping off. Some movements have a small arrow pointing to the correct spot on the lever to depress.
Needless to say, the lever must be depressed and held down while the stem is removed. On most models, the stem will snap back into place again without having to depress the lever a second time.
Steve Maddox
North Little Rock, Arkansas
IHC Charter Member 49
posted March 18, 2004 01:52
Thanks for the advice and knowledge passed along Steve.
I appreciate it.
Cool Cool Cool
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
