stem removal on lady,s wrist watchGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Just a general question, i do not work much on lady,s quartz watches, i want to remove a stem to clean the dial and crystal and case.I have seen on some small mechanical movements a pin you push that disconnects rhe stem. Any thoughts on this? Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | |||
| Watch Repair Expert |
Most modern quartz watches have a little lever that's supposed to be depressed in order to release the stem. The lever should be somewhere near where the stem enters the movement, and it should have a "dimple" in the end of it, which is intended to prevent the point of a sharp instrument from slipping off. Some movements have a small arrow pointing to the correct spot on the lever to depress. Needless to say, the lever must be depressed and held down while the stem is removed. On most models, the stem will snap back into place again without having to depress the lever a second time. =================== Steve Maddox Past President, NAWCC Chapter #62 North Little Rock, Arkansas IHC Charter Member 49 | |||
Thanks for the advice and knowledge passed along Steve. I appreciate it. Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | ||||
