Waltham Mainspring Number Please :) "Click" to Login or Register
Picture of Grant Perry
posted January 22, 2005 22:14
I have an 0 size Waltham Serial #16644987 in need of a mainspring. Would someone be able to tell me the part #? It is a model 1907, grade 165.
Many thanks!
Grant Perry
Posts: 334 | Location: Ottawa, Canada | Registered: January 28, 2003
posted January 23, 2005 00:05
I beleive that it is #2230.
Picture of Kenny Drafts
posted January 23, 2005 01:23
Mike is correct "2230" but they are listed in four lengths;
8 inches long at .14 mm thick
9 inches long at .13 mm thick
9 1/2 inches long at .12 mm thick
10 inches at .11 thick
This spring is listed as being for size 0-3/0 so I would presume the longer length would be for "0" size.Only speculation on my part though.
Smile
Kenny
Picture of Jerry Treiman
posted January 23, 2005 02:52
Hmmm - my Waltham factory mainspring chart says that the #2230 mainspring is 12-3/4 to 15-3/8 inches long with a width of 2.05 mm to 2.10 mm. Thickness (strength) ranges from 0.11 mm to 0.14 mm.
In my 1924 Waltham material catalog they only list a 15"-long spring, so I would guess that the shorter one is later than your movement. Be sure to measure the old one (or use a depth guage) to know which width will fit the barrel.
[Width and thickness have been corrected in response to Kenny's post immediately below. Color my face red].
posted January 23, 2005 03:53
Jerry,
My info is from the "Swigart Manual". It lists the width on all four as 2.06 mms. You have your decimal misplaced on the widths. Would be 2.05 - 2.10.
Grant,
As Jerry says better measure each dimension.
Confused
Kenny
posted January 23, 2005 05:24
Kenny - you are right, of course. I copied the numbers from the chart without thinking if they made sense. The columns were not labeled, but another version indicates the numbers are in "centimeters". I have corrected my post above to avoid confusing people more. The lengths I posted are still correct, with that column labeled "inches".
posted January 23, 2005 10:35
Thanks Gents. I'll measure!
Grant
Grant Perry
posted January 23, 2005 16:16
Okay:
I measured it up, and here is what I found:
1-Length=15 inches
2-width=2mm
3-thinckness=.14mm
Given all the information above, can someone tell me how to/where to oder the correct spring from?
Thank you!
Grant
Grant Perry
posted January 23, 2005 17:31
Grant,
Here are two links that carry #2230 but I can`t figure which one is correct?
DASHTO Mainsprings
S. LaRose
Brian C. might be a source also.
Smile
Kenny
