Waltham Mainspring Number Please :)Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have an 0 size Waltham Serial #16644987 in need of a mainspring. Would someone be able to tell me the part #? It is a model 1907, grade 165. Many thanks! Grant Perry | |||
I beleive that it is #2230. | ||||
Mike is correct "2230" but they are listed in four lengths; 8 inches long at .14 mm thick 9 inches long at .13 mm thick 9 1/2 inches long at .12 mm thick 10 inches at .11 thick This spring is listed as being for size 0-3/0 so I would presume the longer length would be for "0" size.Only speculation on my part though. Kenny | ||||
Hmmm - my Waltham factory mainspring chart says that the #2230 mainspring is 12-3/4 to 15-3/8 inches long with a width of 2.05 mm to 2.10 mm. Thickness (strength) ranges from 0.11 mm to 0.14 mm. In my 1924 Waltham material catalog they only list a 15"-long spring, so I would guess that the shorter one is later than your movement. Be sure to measure the old one (or use a depth guage) to know which width will fit the barrel. [Width and thickness have been corrected in response to Kenny's post immediately below. Color my face red]. | ||||
Jerry, My info is from the "Swigart Manual". It lists the width on all four as 2.06 mms. You have your decimal misplaced on the widths. Would be 2.05 - 2.10. Grant, As Jerry says better measure each dimension. Kenny | ||||
Kenny - you are right, of course. I copied the numbers from the chart without thinking if they made sense. The columns were not labeled, but another version indicates the numbers are in "centimeters". I have corrected my post above to avoid confusing people more. The lengths I posted are still correct, with that column labeled "inches". | ||||
Thanks Gents. I'll measure! Grant Grant Perry | ||||
Okay: I measured it up, and here is what I found: 1-Length=15 inches 2-width=2mm 3-thinckness=.14mm Given all the information above, can someone tell me how to/where to oder the correct spring from? Thank you! Grant Grant Perry | ||||
Grant, Here are two links that carry #2230 but I can`t figure which one is correct? DASHTO Mainsprings S. LaRose Brian C. might be a source also. Kenny | ||||
