Cracked Jewels "Click" to Login or Register
Site Moderator
Picture of John J. Flahive III
posted February 24, 2014 07:53
I recently bought a non-running Hamilton 992 movement with a good staff. After taking it apart, the only thing I can find wrong is three cracked jewels. Does anyone know where I can find these parts?
John III
Posts: 1755 | Location: Colorado in the USA | Registered: October 17, 2005
Picture of Billy Kuhn
posted February 24, 2014 07:59
Buy a parts movement. Take the jewels out of the parts watch. My be someone would have the jewels. Witch jewels are broken??
Thanks
Posts: 1012 | Location: Killen, Alabama in the USA | Registered: January 15, 2013
Site Moderator
posted February 27, 2014 20:20
The upper and lower center jewels are badly cracked. A third wheel jewel has a crack line in it, but the wheel turns freely.
For some reason, I have not been able to find any of these jewels from Hamilton parts suppliers, but I know that this is an easy fix for most watchmakers. Where do they get the jewels?
I am working on getting a parts movement, but I would also like to find a supply of jewels.
John III
IHC Member 376
Watchmaker
Picture of Samie L. Smith
posted February 28, 2014 11:52
John what is the serial number on your movement also do you know the pivot size on the wheel ,i might have what you need.
Site Moderator
posted March 02, 2014 07:52
Samie,
Thanks for the offer. I have a 992 serial number 868851 which has a double roller. The upper and lower center jewels are cracked badly although the wheel spins freely when I assemble the top plate.
Measuring with a digital caliper, I get 0.86 mm on the dial side pivot and 0.43 mm on the bridge pivot.
John III
IHC Member 376
Watchmaker
posted March 02, 2014 12:24
John send me a email i have trouble geting a new email too work but can reply just fine,,
I most likley have the parts you need if not i can replace the jewels in your settings
Picture of Patrick Wallin
posted March 09, 2014 21:13
See what Samie comes up with and then let me know, I have boxes of loose jewels so let me know the sizes of the ID and the OD and the thickness and pivot size. It may take a few days to sort all this stuff but I might be able to help you.
IHC Member 1736
posted March 10, 2014 18:45
I've had good luck with donor jewels with screwed down settings. I've had zero luck harvesting jewels pressed in to the plates.
Crack or shatter them every time.
