February 24, 2014, 07:53
John J. Flahive IIICracked Jewels
I recently bought a non-running Hamilton 992 movement with a good staff. After taking it apart, the only thing I can find wrong is three cracked jewels. Does anyone know where I can find these parts?
John III
February 24, 2014, 07:59
Billy KuhnBuy a parts movement. Take the jewels out of the parts watch. My be someone would have the jewels. Witch jewels are broken??
Thanks
February 27, 2014, 20:20
John J. Flahive IIIThe upper and lower center jewels are badly cracked. A third wheel jewel has a crack line in it, but the wheel turns freely.
For some reason, I have not been able to find any of these jewels from Hamilton parts suppliers, but I know that this is an easy fix for most watchmakers. Where do they get the jewels?
I am working on getting a parts movement, but I would also like to find a supply of jewels.
John III
February 28, 2014, 11:52
Samie L. SmithJohn what is the serial number on your movement also do you know the pivot size on the wheel ,i might have what you need.
March 02, 2014, 07:52
John J. Flahive IIISamie,
Thanks for the offer. I have a 992 serial number 868851 which has a double roller. The upper and lower center jewels are cracked badly although the wheel spins freely when I assemble the top plate.
Measuring with a digital caliper, I get 0.86 mm on the dial side pivot and 0.43 mm on the bridge pivot.
John III
March 02, 2014, 12:24
Samie L. SmithJohn send me a email i have trouble geting a new email too work but can reply just fine,,
I most likley have the parts you need if not i can replace the jewels in your settings
March 09, 2014, 21:13
Patrick WallinSee what Samie comes up with and then let me know, I have boxes of loose jewels so let me know the sizes of the ID and the OD and the thickness and pivot size. It may take a few days to sort all this stuff but I might be able to help you.
March 10, 2014, 18:45
Paul D. TrombleyI've had good luck with donor jewels with screwed down settings. I've had zero luck harvesting jewels pressed in to the plates.
Crack or shatter them every time.
