Cracked JewelsGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I recently bought a non-running Hamilton 992 movement with a good staff. After taking it apart, the only thing I can find wrong is three cracked jewels. Does anyone know where I can find these parts? Thanks, John III | ||
Buy a parts movement. Take the jewels out of the parts watch. My be someone would have the jewels. Witch jewels are broken?? Thanks | ||||
The upper and lower center jewels are badly cracked. A third wheel jewel has a crack line in it, but the wheel turns freely. For some reason, I have not been able to find any of these jewels from Hamilton parts suppliers, but I know that this is an easy fix for most watchmakers. Where do they get the jewels? I am working on getting a parts movement, but I would also like to find a supply of jewels. Thanks, John III | |||
| IHC Member 376 Watchmaker |
John what is the serial number on your movement also do you know the pivot size on the wheel ,i might have what you need. | |||
Samie, Thanks for the offer. I have a 992 serial number 868851 which has a double roller. The upper and lower center jewels are cracked badly although the wheel spins freely when I assemble the top plate. Measuring with a digital caliper, I get 0.86 mm on the dial side pivot and 0.43 mm on the bridge pivot. John III ![]() | |||
John send me a email i have trouble geting a new email too work but can reply just fine,, I most likley have the parts you need if not i can replace the jewels in your settings | |||
See what Samie comes up with and then let me know, I have boxes of loose jewels so let me know the sizes of the ID and the OD and the thickness and pivot size. It may take a few days to sort all this stuff but I might be able to help you. | |||
| IHC Member 1736 |
I've had good luck with donor jewels with screwed down settings. I've had zero luck harvesting jewels pressed in to the plates. Crack or shatter them every time. | |||
