I have a mid 40’s Hamilton 992b and the winding and setting clutch is stuck. I can not back wind or pull the set arm out. I have tried a drip of lighter fluid down the on the winding arbor. Still stuck.
How does that assembly come off the plate?
Posts: 856 | Location: North Ridgeville, Ohio USA | Registered: November 19, 2002
Keith, If you let mainspring down and take the big winding gear off and remove the mainspring barrel plate..There is a clip the holds the winding pinion in..If you just remove the clip the whole assembley should lift out..Also take the dial off and check the gears under it..
Posts: 2028 | Location: Chesapeake City, Maryland in the USA | Registered: September 27, 2011
I did all that you said, and the assembly will not come out. I have pushed, pulled, pried (not so hard to do any harm)beat, poked and prayed still did not move. I am stumped on this one. Next total breakdown and a long soak.
Thanks
Wow..They are usually very easy to lift out..Did the watch wind??I know you said it wouldn't turn backwards..If it winds I would try to find a stem that fits in the winding arbor and with the clip out I would turn it and try to lift at the same time..If that doesn't work I guess it time to soak..I can't think of anything else that would be holding it in..
Wow it was stuck good... I finely got the darn thing free and working like it should. The watch is now running, winding, setting and so far keeping time. This was a good investment as I purchase this 992b in a very nice #10 case, 536 dial with clipped 10 and beautiful black hour minute & second hands. I am so happy when thing work out, Thanks.
Keith
