Trouble Shooting Guide Check List "Click" to Login or Register
IHC Member 1736
posted March 31, 2014 22:29
Thanks Chris, sometimes my military vernacular doesn't line up with civilian vernacular making it impossible for the search feature to find what is so readily available.
fast, slow, pivot, balance, hair, screw, staff, jewel, pivot, time, timer, timing, bph, spring, click, clutch, lever, barrel, main, crown, stem, sleeve, washer, pinion, gear, hand, hands, second, winding, winder, let, down, dial, crystal, bezel, cover, wrist, pocket, watch, did, does, doesn't, won't, run, runs, fit, clear, drag, rub, bent, straight, straighten
Certified Watchmaker
Picture of Chris Abell
posted April 01, 2014 08:10
Paul,
If you go through my checklist I think you will find most of the problems will be identified as you work through it.
Watch Service Check List
