March 31, 2014, 22:29
Paul D. TrombleyTrouble Shooting Guide Check List
Thanks Chris, sometimes my military vernacular doesn't line up with civilian vernacular making it impossible for the search feature to find what is so readily available.
fast, slow, pivot, balance, hair, screw, staff, jewel, pivot, time, timer, timing, bph, spring, click, clutch, lever, barrel, main, crown, stem, sleeve, washer, pinion, gear, hand, hands, second, winding, winder, let, down, dial, crystal, bezel, cover, wrist, pocket, watch, did, does, doesn't, won't, run, runs, fit, clear, drag, rub, bent, straight, straighten
April 01, 2014, 08:10
Chris AbellPaul,
If you go through my checklist I think you will find most of the problems will be identified as you work through it.
Watch Service Check List
