Stem.popping.into.set.position "Click" to Login or Register
IHC Member 1063
posted March 11, 2009 10:57
I.have.a.12S.Elgin.that.requires.pushing.down.on.the.stem.to.wind.and.easily.moves.to.set.position..What.might.the.problem.be?
Dana
Posts: 242 | Location: Massachusetts in the USA | Registered: February 07, 2008
IHC Member 1101
Site Moderator
Picture of Steve Middlesworth
posted March 11, 2009 11:59
Dana,
I have had this problem on several stem set watches and it usually means the sleeve the stem is in needs to be readjusted. These are screwed into the case and have relocated themselves over time. No big deal usually for a watchmaker with the correct tools. I have sent them to Chris Abell on a few occasions.
Steve
Picture of Jerry King
posted March 11, 2009 15:54
I agree with Steve, Dana, because I have one that is the same way and it, too, is a 12s Elgin....Kinda irritating isn't it...?
IHC Member 1063
posted March 12, 2009 09:35
You guys were absolutely right. Put the movement in a different case and the problem was gone. What type of tool adjusts the sleeve depth?
Dana
Site Moderator
Picture of Tom Brown
posted March 12, 2009 09:57
This is the one I have, each end has a fitting to fit different size & type of stem sleeves.
tool
IHC Member 1063
posted March 12, 2009 10:55
Tom-
Are the sleeves like threaded inserts and if so, would a large enough screw driver work? Are new sleeves available?
Dana
Site Moderator
posted March 12, 2009 11:00
Dana
Most are threaded, for you 12 I would say it was.
If you remove the crown & look inside the stem of the watch you should see the end of the sleeve, some have a slot in them like a screw head.
When I get home this evening I can post a few photos of the inside of a case stem.
As far as a new one, yours might be fine, there is a fine line of the sleeve being in far enough to wind but up enough to move into the set position when the stem is pulled up. Brian C. probably would have some, try him at pwpartsetc@pwatch.com
posted March 12, 2009 13:03
Dana, I would try using a screwdriver when I first started, then I bought my Case Stem Tool and could not believe how much simpler it is when one has the correct tool for the job.
I think I purchased the tool here on 185 but can't remember for sure, but no matter, they are not very expensive....you can get one on fleabay, search for 'Sleeve Wrench'....
The one I have looks similar to Tom's, they all look very similar anyway....I noticed on Tom's wrench that is a 9 tool, while mine has 10....
IHC Member 1063
posted March 12, 2009 17:21
That definitely looks like the weapon of choice. I'll find one.
Dana
posted April 27, 2009 17:49
I can not believe that you guy's have forgotten John D. Duvall's "Helping Hands Tutorial".They are right under the repair board on the index page.
