Greetings...does anyone know the proper mainspring replacement number for a 21j 16s grade 105 model IV hampden 1903 movement,actually a little stumped on how to let down the mainspring on this one,the ratchet and winding wheel are covered by the bridge plate and I see no release holes at side of the movement Mark | |||
Mark, I believe the factory number is 3696 w/ a T-end | ||||
Thank You Jon | ||||
IHC Life Member![]() |
Mark, as the click and click wheel are under the dial on this bridge movement, the release is in a hole on the rim. If I was letting this one down (meaning the mainspring is still intact), I would take off the dial, giving direct visual access to the click so you can let it down pretty easily. | |||
IHC Member 1736 |
Thanks guys... I have two of these in line for COA... knowing to go under the hood to let down the main spring is quite helpful. | |||
