Hampden 16s Mainspring Question "Click" to Login or Register
posted January 18, 2014 14:05
Greetings...does anyone know the proper mainspring replacement number for a 21j 16s grade 105 model IV
hampden 1903 movement,actually a little stumped on how to let down the mainspring on this one,the ratchet and winding wheel are covered by the bridge plate and I see no release holes at side of the movement
Mark
Posts: 100 | Location: Virginia in the USA | Registered: May 10, 2009
posted January 18, 2014 16:24
Mark,
I believe the factory number is 3696 w/ a T-end
posted January 18, 2014 16:31
Thank You Jon
posted January 18, 2014 18:25
Mark, as the click and click wheel are under the dial on this bridge movement, the release is in a hole on the rim. If I was letting this one down (meaning the mainspring is still intact), I would take off the dial, giving direct visual access to the click so you can let it down pretty easily.
IHC Member 1736
posted January 18, 2014 20:17
Thanks guys... I have two of these in line for COA... knowing to go under the hood to let down the main spring is quite helpful.
