IHC Life Member![]() |
https://www.youtube.com/watch?v=2R0l6I1yrrk It's kind of boring but if you use a lathe it's an OK video. | ||
Patrick, Well, the presentation is quite a bit longer than it needs to be. Besides that, any information on forming and dressing cutting tools is some of my favorite subject matter! I will submit that using a 1200 grit diamond wheel with a synthetic oil or water based coolant is preferable to dry grinding; you'll get a beautiful razor sharp finish with both high speed steel and carbide, and a 1x6" wheel is not that expensive either: HERE. You'll also need a good coolant: Gem Lube works perfectly with these wheels...for grinding anything! I firmly believe that the key to precise micro-machining is the ability to impart a micro-edge to your micro tools! William | |||
IHC Member 2030 |
There was a post here this year, Mr. White was making graver from micro drill bit? Where do you get the drill bits? Thanks Mike ![]() | |||
I have those micro drills 0.1 mm you sneeze and they break . Also have carbide 1/8 of an inch blanks that are 2-3 inches long any buyers? ![]() | |||
William, I agree. All the way through the video I wondered if he was going to change stones at the end..... | |||
IHC Member 2030 |
William had color coded micro drils, I would be interested in the purveyor of these items. Thanks Mike | |||
Mike, These carbide micro drills are still available through Harbor Freight Tools. They come as random selections and the smallest ones usually have a little shoulder which can be profiled as the one I made. The 1/8" blanks Mr. Kaszubski has work great and can also be held in a standard pin vice. William | |||
IHC Member 2030 |
Thanks, now we are micro ready. Mike | |||
Peter. How much for the 2 - 3 " blanks you have? | |||
Life Member |
Here is here I buy drill bits. They are good to deal with, and do not have a minimum order requirement. They carry bits in a full range of English and metric sizes and materials, including carbide, titanium, and HSS. http://drillcity.stores.yahoo.net/newtuncardri.html | |||
Very nice web site. | |||
