May 01, 2015, 17:46
Patrick WallinHow to make a lathe cutter
https://www.youtube.com/watch?v=2R0l6I1yrrkIt's kind of boring but if you use a lathe it's an OK video.
May 02, 2015, 01:56
William D. WhitePatrick,
Well, the presentation is quite a bit longer than it needs to be. Besides that, any information on forming and dressing cutting tools is some of my favorite subject matter!
I will submit that using a 1200 grit diamond wheel with a synthetic oil or water based coolant is preferable to dry grinding; you'll get a beautiful razor sharp finish with both high speed steel and carbide, and a 1x6" wheel is not that expensive either:
HERE. You'll also need a good coolant:
Gem Lube works perfectly with these wheels...for grinding anything!
I firmly believe that the key to precise micro-machining is the ability to impart a micro-edge to your micro tools!
William
May 02, 2015, 11:46
Mike BendaThere was a post here this year, Mr. White was making graver from micro drill bit? Where do you get the drill bits?
Thanks
Mike
May 02, 2015, 13:09
Peter KaszubskiI have those micro drills 0.1 mm you sneeze and they break .
Also have carbide 1/8 of an inch blanks that are 2-3 inches long any buyers?
May 02, 2015, 16:03
Patrick WallinWilliam,
I agree. All the way through the video I wondered if he was going
to change stones at the end.....
May 02, 2015, 17:46
Mike BendaWilliam had color coded micro drils, I would be interested in the purveyor of these items.
Thanks
Mike
May 02, 2015, 22:05
William D. WhiteMike,
These carbide micro drills are still available through
Harbor Freight Tools. They come as random selections and the smallest ones usually have a little shoulder which can be profiled as the one I made. The 1/8" blanks Mr. Kaszubski has work great and can also be held in a standard pin vice.
William
May 03, 2015, 06:42
Mike BendaThanks, now we are micro ready.
Mike
May 05, 2015, 16:32
Patrick WallinPeter. How much for the 2 - 3 " blanks you have?
June 10, 2015, 16:25
David E. Booth, Jr.Here is here I buy drill bits. They are good to deal with, and do not have a minimum order requirement. They carry bits in a full range of English and metric sizes and materials, including carbide, titanium, and HSS.
http://drillcity.stores.yahoo.net/newtuncardri.html
