How to make a lathe cutter "Click" to Login or Register
Picture of Patrick Wallin
https://www.youtube.com/watch?v=2R0l6I1yrrk
It's kind of boring but if you use a lathe it's an OK video.
Picture of William D. White
Patrick,
Well, the presentation is quite a bit longer than it needs to be. Besides that, any information on forming and dressing cutting tools is some of my favorite subject matter!
I will submit that using a 1200 grit diamond wheel with a synthetic oil or water based coolant is preferable to dry grinding; you'll get a beautiful razor sharp finish with both high speed steel and carbide, and a 1x6" wheel is not that expensive either: HERE. You'll also need a good coolant: Gem Lube works perfectly with these wheels...for grinding anything!
I firmly believe that the key to precise micro-machining is the ability to impart a micro-edge to your micro tools!
William
There was a post here this year, Mr. White was making graver from micro drill bit? Where do you get the drill bits?
Thanks
Mike
Picture of Peter Kaszubski
I have those micro drills 0.1 mm you sneeze and they break .
Also have carbide 1/8 of an inch blanks that are 2-3 inches long any buyers?
William,
I agree. All the way through the video I wondered if he was going
to change stones at the end.....
William had color coded micro drils, I would be interested in the purveyor of these items.
Thanks
Mike
Mike,
These carbide micro drills are still available through Harbor Freight Tools. They come as random selections and the smallest ones usually have a little shoulder which can be profiled as the one I made. The 1/8" blanks Mr. Kaszubski has work great and can also be held in a standard pin vice.
William
Thanks, now we are micro ready.
Mike
Peter. How much for the 2 - 3 " blanks you have?
Here is here I buy drill bits. They are good to deal with, and do not have a minimum order requirement. They carry bits in a full range of English and metric sizes and materials, including carbide, titanium, and HSS.
http://drillcity.stores.yahoo.net/newtuncardri.html
Very nice web site.
