Cleaning a gilt movement "Click" to Login or Register
I am working on an E. Howard N size gilt movement that was covered with what might be dried grease or oil. I have run the movement through an ultrasonic cleaner and soaked the affected parts in Naptha when they were still dirty, but to no avail. Because it is a gilt movement, I cannot use a hard abrasive. I am hoping that someone in this group has had the same experience and may have some suggestions on what I can do.
Posts: 353 | Location: Nichols, New York in the USA | Registered: April 04, 2010
main plate
Tat is a toughie. I had a French clock come in for repair that had gilt plates with a similar problem. I was never able to find anything that would clean it. A little judicious scraping in a hidden spot, and a look-see under a 40x stereo microscope seemed to indicate that the gilt finish was gone under those spots, but I was never sure. I documented the problem with photographs and told the client. I returned the clock repaired and mechanically good, but was unable to do anything about the discoloration.
IHC Member 1541
Picture of Lorne Wasylishen
Administrative Assistant
Picture of Dr. Debbie Irvine
Thanks Lorne for providing the link to one of our previous informative discussions!
Smile
Posts: 5839 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
