Balance Bridge Holder ? "Click" to Login or Register
Picture of Patrick Wallin
Does anyone make a Balance Bridge holder that will
hold the bridge steady and not allow it to revolve on the shaft.
Most holders are just a pin mounted into a base. These allow the bridge to rotate while you are trying to work on it. They can be frustrating at times.
Picture of William D. White
If the pin has just a slight taper, push the balance cock down a little to see if the pin will tighten slightly inside the screw hole. I've never owned one of these simple tools so I can't say with any certainty if this will work.
William
Good idea. I"ll try it.
Thanks William.
