November 19, 2014, 17:28
Patrick WallinBalance Bridge Holder ?
Does anyone make a Balance Bridge holder that will
hold the bridge steady and not allow it to revolve on the shaft.
Most holders are just a pin mounted into a base. These allow the bridge to rotate while you are trying to work on it. They can be frustrating at times.
November 20, 2014, 02:41
William D. WhiteIf the pin has just a slight taper, push the balance cock down a little to see if the pin will tighten slightly inside the screw hole. I've never owned one of these simple tools so I can't say with any certainty if this will work.
William
