Balance Bridge Holder ?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Does anyone make a Balance Bridge holder that will hold the bridge steady and not allow it to revolve on the shaft. Most holders are just a pin mounted into a base. These allow the bridge to rotate while you are trying to work on it. They can be frustrating at times. | ||
If the pin has just a slight taper, push the balance cock down a little to see if the pin will tighten slightly inside the screw hole. I've never owned one of these simple tools so I can't say with any certainty if this will work. William | |||
Good idea. I"ll try it. Thanks William. | |||
