Crystal Cleaning "Click" to Login or Register
IHC Member
posted February 15, 2008 15:53
I've been trying to clean up a crystal that has an uneven cloudy type appearance,mostly on the inside.This is from a salesman's case that looks unused. Both glasses are scratch free; only one has the "stain" and the crystals were glued in.I don't think the problem is glue, but I'm not sure.
I started with cerium oxide, but gave up and went to #400 grit silicon carbide. I've been at it long enough to wonder what I'm up against-I've had scratches come out easier! If I didn't know better(?) I'd suspect the glass absorbed something...somehow.
"Search" didn't get me far, and it looks like a 30 minute job is going to take hours-unless somebody knows something that'll help...?
Marty
Posts: 506 | Registered: October 26, 2007
IHC Vice President
Pitfalls Moderator
posted February 15, 2008 19:01
Hi Marty, welcome to IHC 185. If you find out how to do that, I'd also be interested in hearing about it.
I never heard of anything beyond polishing out scratches. Is this a glass or plastic crystal?
Watchmaker
Picture of Scott Cerullo
posted February 15, 2008 19:11
Marty,
There are many things that can etch right into the glass. Etching Cream (and I don't mean itching cream), is one of them. You might be in the market for a new crystal for that one. Do you have a picture that you can post?
IHC Member
posted February 15, 2008 20:17
Ed and Scott- Yes,it's glass-and I'll try and get a pic'; like I said there's no scratches just a foggy,blotchy-type stain. I was afraid it was super glue, but acetone didn't help. Let me try for a pic- shoot-I give uP!!!!
Marty
Moderator
Picture of Donald Trumble
posted February 15, 2008 20:36
Posts: 504 | Location: Pennsylvania in the USA | Registered: April 02, 2005
IHC Member
posted February 15, 2008 21:35
TRYING-
Marty
IHC Member
posted February 15, 2008 21:37
i
Marty
IHC Member
posted February 15, 2008 21:42
FINALLY! I hope this'll get me some answers- those threads above from Don (thanks!) helped me for other problems but not this-anyone seen this? Remember the crystal was glued-maybe super glue-does it stain glass?
Marty
Certified Watchmaker
Picture of Chris Abell
posted February 15, 2008 21:59
Hi Marty
maybe easier to remove the crystal first then give it a wipe round with some nail varnish remover (acetone) if that doesn’t work soak it overnight in ammonia, if still no joy work a solution of Cerium oxide and polish back, if that don’t work drop in trash and find a new one Smile
IHC Member
posted February 15, 2008 22:07
Chris I've done all that-I just can't believe something could be absorbed into glass-maybe I'll just get my drill and work the silicon carbide into it for a couple hours...I'll try a while longer;I'm supposed to be trying to blue hands but I got this salesman case free and unused.
Marty
posted February 21, 2008 16:38
Hi Guys
I read somewhere that glass does actually absorb moisture. For example glass decaters in a damp atmosphere will go cloudy.
Also that glass always remains a "liquid". If you measure the thickness of the top of a piece of old glass in a window and then the bottom. typically the glass will be thicker at the bottom, where the glass has run down over the years. D
oesn't help much on the watch glass question but just thought you would be interested.
If it were me I'd throw it away!
Posts: 264 | Location: Westbrook, United Kingdom | Registered: June 15, 2007
Picture of James H. Miller
posted February 21, 2008 19:20
hi i went to a class for stained glass there they said it will fully harden in about 2000 years
Posts: 279 | Location: Wheatridge, Colorado in the USA | Registered: January 20, 2008
IHC Member
posted February 22, 2008 13:24
OK -Maybe most people would toss it,but I need to learn and see what can be done. So me and my rotary tool went through a few felt pads. I went back to #600 grit silicon carbide-no cerium oxide yet;maybe later.
For those interested(like me)in what could have caused this damage,here's a clue-after removing the worst of the "stain" I saw a pattern of tiny pin pricks covering the glass.These have lightened some the more I work.Very strange.
Marty
2008-02-22crystal #1
IHC Member
posted February 22, 2008 13:26
Another pic'...
Marty
crystal #2
