  European Pocket Watch Forum
  Need help identify/valueGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1016 |
 Here is a watch I bought when I was first aquiring.  It is interesting and I thought I might sell it either here or ebay.  When I took the movement out of the case I noticed the "brand" on the movement.  Now, I know this isn't a $20,000 Breguet!  What I'd like to know is what it is.  The case is Sterling marked, and the watch runs.  | ||
| IHC Member 1016 |
 The full image  | |||
| IHC Member 1016 |
 Movement  | |||
| IHC Member 1016 |
 More markings  | |||
| IHC Member 1016 |
 Some other marking  | |||
| IHC Member 1016 |
 Still more  | |||
| IHC Member 1016 |
 The case is hallmarked.  Any ideas as to what this is and if there is real interest on this forum?  | |||
| IHC Life Member  Site Moderator  |
 So far I think the silver hallmark on the case is Swiss from 1882-1934. Also found where; S.G.D.G. Sans garantie du Gouvernement is a disclaimer required by the government of France stating that it does not guarantee enforcement of the claimed patent Also the word Brevete is French for Patent. Now all of this is from a guy in the southwest who can only speak English so I could be full of hot air. Tom  | |||
 Mike Your watch is a swiss made dating about 1900 with 'exposed balance' Breveté S.G.D.G. means swiss patent (patent writen in french not patented in France = from the french speaking part of switzerland) The patent #16598 was taken by Ernest Degoumois St-Imier on mai 4th 1898,he had also the 'bonheur' label protected. The headline was 'watch with less height with visible balance' (translated) The patent was signed by A. Mathey Doret (Chaux de Fonds) wich I think was the maker. Your watch is the 7j model ( a 15j version also exits). Unfourtunately those nice watches do not sell high. I found one sold for $100. Regards, Gerald  | ||||
| IHC Member 1016 |
 Thanks Gerald and Tom,  Good information.  I don't know if there is sufficient interest to sell it here.  It is a nice watch.  | |||
 Mike,  The watch appears to be based around the 'Hebdomas' types, which also have visible escapements. Have you checked to see how long it will run on a full winding? The Hebdomas watches I would say most folks are familiar with, have the lower half of the dial shaped so as to reveal the balance and a highly decorated bridge, plus some of the lever arrangement too. Check out the 'Hebdomas' topic in this forum for some examples! The major plus with Hebdomas types, (also quite a departure for Swiss offerings), is that everything is interchangeable - and that goes for the 'Non Patent' types which masquerade as the real deal. You've got some good information here and I can't add a lot to it except the following. The script 'Avance - Retard' on the dial either side of the regulator index, suggests the watch was made for French speaking nations and not a general export model. The grade of silver used at .875, is also slightly higher than mainstream Swiss offerings, which are generally 0.800, anything above either is generally found on Sterling silver imported goods and of 0.925 or 0.935 grade. The marks on your watch refer to a period after 1880, so Gerald's dating of it is probably about right. The statement 'Ancre Ligne Droite Interchangeable' translates (generally) to: 'Anchor Escapement, with Interchangeable Straight Line Lever' The fact that this information has been engraved on the movement, would suggest it was being used as a marketting ploy, and manufactured in the era when sidelever escapements (and cylinder types) were being superceded by the 'straight line' lever, which are more compact and facilitate the manufacture of much thinner movements. To make a point of it alludes to the watch being better than that of a competitor not having one! Sort of 'Horological Snob value' With a few exceptions, pretty much all the lever ecapements you will come across today in both Swiss and American watches will have straight line lever escapements. These type watches do well this side of the pond, not sure how you will fare with a sale in the USA. The last Hebdomas I sold went for £120 Sterling, but it was a traditional Hebdomas type.! Your watch looks to be a Very nice example, hope you do well with it! Best regards John  | ||||
