Anyone know what this is? Please help "Click" to Login or Register
IHC Member 1338
posted August 20, 2013 00:43
A customer is liquidating his collection
and this was in there...he called it a "miners protective case" housing what I think may be an English verge fusee? Watch itself is 12/14S. Customer knows absolutely nothing about it other than that. Silver case mvmt signed "Thomas Evans---Lampeter" pretty neat setup the entire watch bow and all fit up in the miner's? protective case.
It has obviously done it's job as the watch inside is in excellent condition and runs altho dont know how long.
It'll be for sale once I figure out what it is...
Any ideas? I lost pics of hallmarks but it's definitely English and maybe 1850-1870 era?
Any help appreciated
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
posted August 20, 2013 04:39
brass pair case - very odd style
based on the 2 - if that is 2 ounces, I would not doubt the miner connection, that would be a very sturdy case, most pair cases were not that heavy.
Posts: 5101 | Location: Buffalo, New York in the USA | Registered: November 11, 2009
IHC Member 1541
Picture of Lorne Wasylishen
posted August 20, 2013 11:55
Miners Case Search
Tom, what are you using that enables you to put all of those photos in one post?
IHC Vice President
Pitfalls Moderator
posted August 20, 2013 13:19
He's just using externally hosted images. When you do that, you can put as many images as you want wherever you want using html commands. It's not recommended for long-term posts, as externally hosted images tend to go away.
IHC Member 1541
posted August 20, 2013 14:48
Thanks Ed, I tried it a few times with Picassa but it just made me tired.
I can put them side by side from iPhoto then take a screen shot , adjust size and post. Works for me.
posted August 20, 2013 17:34
Hi Tom
A very nice watch with some history.
The watch is british ,no verge, no fusee!
Is has the english lever escapement (two banking pins).
To obtain the british counter clockwise winding it has reversing wheels under the dial (note the small distance from winding square to mainspring barrel radius). I think this watch was made ca 1880 and could been manufactured by William Ehrhardt (English Watch Company) Birmingham.(the casemarks would help a lot). The watchmakers name on the watch is the name of the finisher or trader of the watch.
Lampeter is a small town in Wales. I could not find a Thomas Evans as a watchmaker but some T J? F? Evans pocket watches and there was a Thomas Evans clockmaker in a small village nearby.
The outer case is a protective case and i think the watch was owned by a welsh coal miner. The protective case shows at least two watchpapers, the blue and visible one reads:
W(illiam) Woolsey ; Watchmaker Jeweller & ??; 13 Market St(reet); Gainsboro
He was ancestor to our member John Woolsey and took care of this watch long time ago !
That's why i like this hobby: watches tell stories don't they ?
Gerald
IHC Member 1338
posted August 20, 2013 18:28
Thank you, Gerald! Here are the case marks if that tells you anything please post
Tom Dunn...
TIME MACHINE
posted August 20, 2013 18:53
This set of three marks are
sterling silver (lion) Birmingham (anchor) 1892 (date letter 's')
My first guess on this watch was not too bad spotting the location and missing just 12 years by looking on a fullplate back Smile
The inner side of the case should have the full set of four marks includung the casemakers mark.
Gerald
IHC Member 1338
posted August 20, 2013 20:15
Gerald; It does, but I sent it up to my watchmaker to check. I'll post the other set when I get it back. So it may be an Erhardt?
Tom Dunn...
TIME MACHINE
Picture of David Flegel
posted August 20, 2013 20:40
https://ihc185.infopop.cc/eve/f...043991677#8043991677
Have the same piece. It is a miner's case or a case for anyone working in dusty environment where the watch might get banged around.
Posts: 1212 | Location: Ontario in Canada | Registered: February 06, 2012
posted August 20, 2013 21:42
Ehrhardt is the closest match with the given characteristics of the movement but to be sure a picture of the faceplate should be taken. I am sure there are some marks on the movement to find out the maker.
Gerald
Site Moderator
Picture of Tom Brown
posted August 20, 2013 22:00
There was a Thomas Evans born about 1845 in Wales. In the 1911 census he is listed as living in Lampeter, Cardiganshire, Wales. In the census he is listed as a "watchmaker (dealer".
He is also listed in 1881 same city as a "watchmaker".
posted August 20, 2013 22:13
Thank you Tom
While the census records are in English other sources mix english ane welsh names (Lampeter =Llambed or Llanbedr)
Gerald
btw: Has someone informations about John Woolsey?
Site Moderator
posted August 21, 2013 08:03
I use to stay in touch with John, but a about a year ago my emails go unanswered, I miss talking with him!
posted August 21, 2013 13:41
Page 447 of the 2013 fat book shows this balance cock design as: "1810-1865 'look' (outline design)for barrel bridge (type movement)" . . . A description that corresponds with some of the other replies in this posting.
Judging from the brass case marked "2", this could have been a "Watch Man's" timepiece to be carried (with the protective brass case) while "ON THE JOB".
Interesting note, as men were assigned to keep "watch" all the way back to cave housed groups and much later began to carry time pieces to signal the time when "all is well". . .
Would it be correct to presume that is where our name "watch" came from.
Site Moderator
posted August 21, 2013 19:56
Gerald
Just got a note from John!
posted August 21, 2013 20:17
I hope it's good news.
Gerald
Site Moderator
posted August 21, 2013 22:19
Gerald
I don't see an email listed for you, if you want to drop me a line my address is listed.
