I am going to attempt servicing an 18s FP grade 73 Elgin 1894 movement Can anyone give me a tip on how to let down the spring on these full plate models?? I also have a grade 3 Wm Ellery Waltham FP I need to let down
Thanaks,Mark
Posts: 100 | Location: Virginia in the USA | Registered: May 10, 2009
You will notice the small hole that I made a line to, while holding onto the winding tool insert a small pin type object into the little hole, this will disengage the click as seen in photo 3
Posts: 5107 | Location: New Mexico in the USA | Registered: January 27, 2007
I went ahead & took one more of the Waltham with the bridge removed, you can see the other inside of the lever & how when you move it, it moves away from the gear.
Good explanation...I would add that you should turn your holdback tool in a clockwise (winding) direction while pushing on the pin or lever. This unloads the tension off the gear. Then you let the tool slip thru your fingers in a controlled let down.
Posts: 1078 | Location: Ticonderoga, New York USA | Registered: March 01, 2008
Just to resurrect this little instruction on how to let down the mainspring. Exactly what I needed. I haven't done a teardown on an Elgin before. Works like a charm when you know what to do. Thanks Tom.
Dave Turner
Posts: 1979 | Location: Wilson, North Carolina in the USA | Registered: November 15, 2011
