Roman Numerals "Click" to Login or Register
Picture of David Flegel
posted March 14, 2012 08:51
Does anyone know why the roman numeral IV is IIII on watch faces?
Posts: 1212 | Location: Ontario in Canada | Registered: February 06, 2012
Picture of Eugene Buffard
posted March 14, 2012 09:35
Most likely back in the 1880s it was confusing just like today. So some smart guy said lets put 4 of these IIII on the dial.
Back then six grade edumacation was standard. And yes I meant to spell it like that.
Posts: 3326 | Location: Illinois in the USA | Registered: July 06, 2010
posted March 14, 2012 10:36
I believe it has more to do with balance. The eight on the other side is VIII and it looks more balanced to have IIII for the four than IV. Don't forget a watch is as much a piece of art and jewelry as it is a timepiece.
Picture of Brian C.
posted March 14, 2012 11:03
Roger,I believe you have the correct answer.
posted March 14, 2012 11:24
This 1396 vintage Wells Cathedral Clock indicates "IIII" instead if "IV" was an early habit with timepieces.
IHC Vice President
Pitfalls Moderator
posted March 14, 2012 11:25
That's a nice example David.
Why? I agree with Brian, Roger has the correct answer. It's all about dial aesthetics.
Picture of Peter Kaszubski
posted March 14, 2012 12:19
David do you want to sell that clock Wink
posted March 14, 2012 12:51
Sure and I got a piece of land in the Yukon that never goes below 80F.
IHC Member 1142
posted March 14, 2012 13:47
MAYBE IT WAS BECAUSE IV STOOD FOR THE ROMAN GOD JUPITER AND THEY DIDNT BELIEVE IT WAS RIGHT TO DIPLAY THAT ON A CLOCK
Posts: 220 | Location: McDonough, New York in the USA | Registered: June 01, 2008
Picture of Jerry King
posted March 14, 2012 14:00
Here are some suggestions as to the why's and whyfor's....
Wikipedia:
"IIII" on clocks....
Clock faces that are labeled using Roman numerals conventionally show IIII for four o'clock and IX for nine o'clock, using the subtractive principle in one case and not the other. There are many suggested explanations for this:
. Many clocks use IIII because that was the tradition established by the earliest surviving clock, the Wells Cathedral clock built between 1386 and 1392. It used IIII because that was the typical method used to denote 4 in contemporary manuscripts (as iiij or iiii). That clock had an asymmetrical 24-hour dial and used Arabic numerals for a minute dial and a moon dial, so theories depending on a symmetrical 12-hour clock face do not apply.[22]
. Perhaps IV was avoided because IV represented the Roman god Jupiter, whose Latin name, IVPPITER, begins with IV. This suggestion has been attributed to Isaac Asimov.[23]
. Louis XIV, king of France, who preferred IIII over IV, ordered his clockmakers to produce clocks with IIII and not IV, and thus it has remained.[24]
. Using standard numerals, two sets of figures would be similar and therefore confusable by children and others unused to reading clockfaces: IV and VI are similar, as are IX and XI. As the first pair are upside down on the face, an additional level of confusion would be introduced—a confusion avoided by using IIII to provide a clear distinction from VI.
. The four-character form IIII creates a visual symmetry with the VIII on the other side, which the two-character IV would not.
. With IIII, the number of symbols on the clock totals twenty Is, four Vs, and four Xs,[25] so clock makers need only a single mold with a V, five Is, and an X in order to make the correct number of numerals for their clocks: VIIIIIX. This is cast four times for each clock and the twelve required numerals are separated:
.V IIII IX
.VI II IIX
.VII III X
.VIII I IX
The IIX and one of the IXs are rotated 180° to form XI and XII. The alternative with IV uses seventeen Is, five Vs, and four Xs, requiring the clock maker to have several different molds.
. Only the I symbol would be seen in the first four hours of the clock, the V symbol would only appear in the next four hours, and the X symbol only in the last four hours. This would add to the clock's radial symmetry.
