Has anyone ever seen a " Pocket Watch" like this?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
This is a Waltham Pocket Watch, serial # 28010963. It is very heavy. It is made of pure steel all the way through. The case is made of the same material as the movement. The movement has two main springs a Breguet Spring balance and 7 jewels. It would not be a very practical “pocket watch” unless you were Paul Bunyan. It weighs about 10 oz, and is about ½” thick. I cannot find much information o this one. I did look up the serial # in the data base, it is a Waltham. Any history would be nice, why would anyone want such a bulky, “pocket watch”. There has to be an explanation for it. | |||
Some more of this one | ||||
Another | ||||
Perhaps it was a Railroad Engineers watch. Maybe he carried it in the engine and they made it so it could not break in that environment. Pure speculation and a dreamers view. | ||||
Stephen, What you have there is a Model 1926 8-day clock. It is a size 37 and not designed to be carried. Here is the what came back from the Waltham serial number lookup page linked in out Technical Library: http://www.nawcc-info.org/WalthamDB/LookupSN.asp | |||
Thanks, I already did that. I looking for a history, why would someone have a so called watch that was that big or heavy. All clocks and watches are made for one purpoe or another, why was this one made this way. | ||||
It is most likely an automobile clock that was an after market accesory and fastened to the dashborad someway. I once had one that someone had made a nice walnut case for; best I can remember it was sorta oval in shape. Sears was selling them in 1927, but the page with automobile clocks (491-92) is missing from my copy of the reproduction issue so I don't know which brands they were offering. | ||||
Now there is a possibility! It's fun to speculate about clocks and watches. Where have they been, who had it who held it, was it a keep sake or just a tool. You just have to wonder. That's what collecting and repairing this stuff does to you. This one I will fix and use as a good paper weight or just a conversation piece. Putting it into a ships style chronometer box might be good too. Still I will wonder, where has it been, why did Waltham feel it necessary to make one like this. Thanks for the thought. | ||||
There are two design features I see in this watch that insist this was purpose-built. The heavy all-steel casing (check it with a magnet) suggests that it was made to resist external magnetic fields. Possible in an industrial or vehicular situation etc. with high electro-magnetic fields, where a timepiece is important. The stepped down diameter of the actual dial suggests it was panel-mounted in a limited space but shock-free component of the machine it was attached to. These movements DID NOT LIKE shock and vibration! | |||
Perhaps like an airplane. I found where Lindburg had a Waltham Watch mounted in a wood case in the Spirit of St Louis. Great observation. Another posibility and, I believe, a little closer to the real purpose of the watch. | ||||
David I did what you said, I checked with a magnet. It is not steel, possibly nickle? Putting it in a case like this would mean exactly what you said, a situtation where a high magnetic field would make the watch inaqurate and render it usless. One step closer. Thanks. | ||||
I am going through the same thing with a 4.5 ounce 8-day ![]() | |||
That is ALL aluminum, movement! The movement plates, and case! ![]() | |||
Looks like the same style movcement, I found a bit more about it. EA5 American Waltham Watch Co. 37 Size - Open Face - Gilt or Nickel Model 1907, 1910 & 1926 Pendant Set 8 day ![]() | ||||
