can't get the movement out of case "Click" to Login or Register
I picked up a Lady Elgin 6/0s on ebay for 13 bucks. It's in beautiful shape and was advertised as not working. I tried to get the movement out of the watch this morning, but it doesn't seem to want to come out. I can tilt it and the bottom is almost out, but it just won't come loose. I don't want to force it.
I was thinking the stem might be in too deep, but without getting the watch out, I can't loosen the crown.
What can I do?
Funny enough, when I was toying with it, I loosened a screw on the bridge plate and the watch started to tick. It's still going a couple of hours later. But of course I want to clean and oil it still.
Posts: 152 | Location: Miami, Florida in the USA | Registered: August 11, 2009
Hi Dale,
That one will likely have a detent stem.
Assuming it does then look for a little hole where you insert a probe and press or perhaps a screw to loosen half-turn-at-a-time until it releases. If I am correct one or the other of those should be pretty well in line with the crown. But not being specifically familiar with this particular movement I am not certain so at this point that is about all I can think of.
Like you my friend, the adage "do no harm" is always foremost.
These are really nice and sad to say vastly underappreciated watches. I am please someone is serious about saving them, good for you!
Thanks so much. It has a little screw that when loosened the stem assembly slipped out. I had no idea that was the case.
Yes, I have fallen in love with the little ladies. When they come available on ebay, I can get them for ten, twelve dollars. Last night I bought another one for ten, and the seller says it runs.
I don't know if when I clean and oil them they'll have that much resale value, but I just like them and figure if I can work on something that tiny I can work on anything!
The solid gold ones are much sought after, but not the little gold filled ones I think. But alot of them have original bracelets.
I'm going to wear this one myself.
