Illinois grade 99 with screw down crownGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1418 Railroad Time Inspector |
I have a grade 99 Illinois serial 294506 it has a interesting screw down crown with what I presume is a key for the stem, since it is a key wind did they produce this style incorporating a key which fit over the stem? Since there is no stem how did the key set the time? | ||
The Model 1 Grade 99 was a KW~KS watch. The same key should wind the watch from the back-side and on the front-side it should fit in the center of the hands on a "square" post and allow one to set the time. Is that the question as I understand it ?? regards, bb | ||||
At first thought that was what I imagined but in this case the hands are pressed on a round pinion. Unless some one changed this there is no way to set this watch. I was suspecting that the key attached to the crown some how activated the stem? | |||
Before I go ripping things apart I sort of like to have a idea what I should expect. It just is very strange with the screw down crown and what I presumed was a key. | |||
How about posting some pictures of the back, the front with bezel off, the key screwed down in place and the key unscrewed and out of the pendant and perhaps a shot down into the pendant. It sounds like a "hidden key" case. The key should fit the winding wheel on the back-side ?? regards, bb | ||||
Walter, your Grade 99 is SUPPOSED to be a 5th pinion transitional Key wind movement that is actually made to be lever setting and pendant wound. I had a few of these go through my collection and they all looked sort of like the one below. If yours is actually in a hidden key case, the case is actually worth about ($300.00-$400.00) three times the movement and the movement should be switched to a "normal" Pendant wind lever set OF case. ![]() | |||
Thanks David, as that was what I suspicion-ed when I suggested that pictures be added to make certain. Saving all the pictures that you have over the years David and then posting them when questions arise is very helpful. I for one appreciate that you have saved them and that you post them, and of course your always spot on helpful information so Thanks !! regards, bb | ||||
Thanks fellows, the watch is the same as the one Dave showed. I guess I will move it up the line and do some tinkering. Always a pleasure to have you share your thoughts and expertise. Thanks again. | |||
