I bought a Ham 974 "beater" just to harvest parts, but specifically the dial as it should be 4 footed and I need one. The case is a mess, and the bezel will NOT budge. I tried oil, soaked it in acetone in case it was superglued, and eveything else I could think of but no luck. Since the case is totally shot could the bezel be cut off without damaging the dial? Obviously I am not a case expert, but it seems there could be a jewelers tool that would cut the bezel in two and I could pry it off, Experts?????
Posts: 3112 | Location: Klamath Falls, Oregon in the USA | Registered: October 13, 2007
I'm certainly no expert Mike but if done slowly and very carefully I think the bezel could be sliced down through the threaded section and removed. If it were me, I would use a nice sharp hand saw and have the case securely clamped down to prevent it or the saw blade from slipping. And work very slow and patiently. I would of course wait for some of the other members to chime in before attempting it though.
Ray
Posts: 1501 | Location: Rancho Cucamonga, California USA | Registered: December 20, 2006
Usually the soft rubber cups made for the purpose of case-back and bezel removal will do the job.
I suppose if the case is expendable you could put the frame in a bench vise and try a pair of channel lock type pliers. If that fails a small hammer and chisel used with care could be the answer.
Let us know how this ends!
Posts: 10553 | Location: Northeastern Ohio in the USA | Registered: November 19, 2002
Hi Mike, I have never seen a case I could not open. With saying that there is always a first. If you have or can get one of the soft cups I would try that. Now the trick is instead of pushing down and turning, as most everybody does. Just start turning the back with very little down pressure. Most of the time dirt will get in the treads and by putting pressure on the case you are locking the dirt in the treads and it will not budge.
Just a thought ~ Leon
Posts: 296 | Location: Livingston, Tennessee USA | Registered: May 20, 2006
Thanks to all who responded. I ended up taking it to a local jeweler and he used a rubber band and got it to unscrew. I have to think it was because I had loosened it for him The dial in question was indeed 4 footed and is much better though not perfect.
Hey Mike,I cut one off with my Dremel tool,a little while back,without any damage to the dial. The dial was already ruined,but I still didn't touch it with the Dremel. I have found the best way to remove tight bezels is simply to put on a pair of surgical gloves. Gives you amazing grip on the cases.
Posts: 475 | Location: Gainesville, Florida in the USA | Registered: January 22, 2009
The first thing I do when a bezel won't budge is grab a wad of Rodico. I formed it across the bezel and crystal and it usually gives me the kind of grip necessary to get things spinning. Check it out...works almost every time.
Posts: 718 | Location: Upstate New York in the USA | Registered: November 21, 2008
