Tool Quiz "Click" to Login or Register
I have been wanting one of these for a long time and finally got it. Who knows what it is?
IHC Member 1291
It would appear to be perhaps a feeler gauge maybe to measure clearance between balance and plate Confused
Disclaimer;Anything that is printed on this page is purely fictional, and is in the context of an alternate virtual reality in a parallel universe.
Another words,I am taking a wild guess Big Grin
Sorry Buster...Nope.
Very interesting Roger,
I have never seen anything like it, but my impression is of a scale for weighing something very small and it appears like over to the right on the horizontal meter is where it can be zeroed. I must admit to being completely stumped! Confused But I also think the picture is likely the back of whatever this device is.
Lindell,
You are on the right track. The picture is of the front of the tool.
It is a Balance wheel weight scale for weighing and "pairing" balance weights for Balance wheels.
David has it. I'm sure he meant balance screw weight scale. This device is sensitive enough to measure the weight of an individual balance screw. Where the slot is on the right side is a small cup with a hole in the bottom of it. The balance screw is placed in the cup with the threaded part thru the hole. The slider on the top is then moved to the left until the cup comes back up to the original starting position. You read the number on the scale and then match a screw to that number. It is also important to know the starting weight of your balance wheel...assuming that it is vibrated correctly to begin with. You can't simply add and subtract weight to poise the balance without maintaining the same weight of the entire balance wheel.
Picture of Edward Kitner
This is a great thread Roger. I'll bet their are others out there that have unknown tools that they could share with us.
WOW!!!
That is absolutely fascinating and your explanation is easy to understand.
Hey Roger, Your last sentence about maintaining the same weight of the balance wheel is a little confusing. I thought the purpose of the weights was to time the watch. Such as adding weight to slow it down or removing weight to speed it up. Either way the total weight of the balance wheel will be changed.
The old fashioned way of doing the same thing is to use a piece of mainspring straightened out and balanced on a knife edge pivot. The straightened mainspring is then trimed until equilibrium is obtained. The balance screws which you are working on are then placed on oposite ends of the mainspring.
Regards, John
Cecil,
Yes, you are correct that adding or subtracting weight speeds up or slows down the watch and the overall weight of the balance is changed. If you note in my previous post I stated that the starting weight of the balance is important assuming that the balance assembly is vibrated correctly to begin with. This means 18,000 oscillations per hour. (Most of the time.) When you add or subtract weight you are attempting to bring the balance as close to that 18,000 number as possible. That allows small adjustment afterward to be made with the regulator. If you add or subtract weight to get there and you don't have the exact amount of change on opposite sides of the balance, then the balance is now out of poise which means accuracy in positions is compromised. Now a watch with timing screws makes life a lot easier. The weight of the balance is not being changed. By turning the timing screw out you place more weight on the outer perimeter of the balance assembly and slow down the balance. Turn it in and it speeds up. Theoretically poising does not change. I find it fascinating how all this was done with such great accuracy so long ago when so many factors enter into fine watch timing.
