A little daily humor - title - mainspring w/ a lil twist "Click" to Login or Register
No run on this 6 sz Elgin
Hmmmm - Eek
It makes my head hurt thinking of how this was supposed to work in theory
The is why one must ALWAYS check for sure which way the mainspring goes into the barrel as this happens when you try to wind a reversed mainspring. If you are lucky, it may still be reshaped and installed the right way..
Site Moderator
Picture of John J. Flahive III
Good grief. Eek
I always take pics and/or draw a little picture of the way the MS is wound before removing it.
I have lots of mainsprings if you need a new one.
John III
Posts: 1755 | Location: Colorado in the USA | Registered: October 17, 2005
IHC Member 1736
Yep, been there, done that... If you see one of my tear down cards and it has a "snail" drawn on it, you can bet I've had the main spring out.
It took me awhile to get through the dyslexic relationship between the barrel and the winder... I finally have a routine that saves me from this.
Pain is a wonderful disciplinarian.
Picture of Patrick Wallin
That type of mainspring is called a slipandcatch. It's like a hit and miss engine. It catches every other time. How the heck did it get on the wrong side of the arbor? This is just me but I would pull the arbor and see if I could straighten out the spring so it will catch. That is of course after I made sure it was still good. 1/2 the barrel is filled so it might even be the right one. Just set in the barrel backwards. I know the winders used to confuse me too but that don't take much.
Picture of Peter Kaszubski
another butcher/shoemaker/blacksmith work!
