A little daily humor - title - mainspring w/ a lil twistGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
No run on this 6 sz Elgin Hmmmm - It makes my head hurt thinking of how this was supposed to work in theory | |||
The is why one must ALWAYS check for sure which way the mainspring goes into the barrel as this happens when you try to wind a reversed mainspring. If you are lucky, it may still be reshaped and installed the right way.. | |||
Good grief. I always take pics and/or draw a little picture of the way the MS is wound before removing it. I have lots of mainsprings if you need a new one. John III | |||
| IHC Member 1736 |
Yep, been there, done that... If you see one of my tear down cards and it has a "snail" drawn on it, you can bet I've had the main spring out. It took me awhile to get through the dyslexic relationship between the barrel and the winder... I finally have a routine that saves me from this. Pain is a wonderful disciplinarian. | |||
That type of mainspring is called a slipandcatch. It's like a hit and miss engine. It catches every other time. How the heck did it get on the wrong side of the arbor? This is just me but I would pull the arbor and see if I could straighten out the spring so it will catch. That is of course after I made sure it was still good. 1/2 the barrel is filled so it might even be the right one. Just set in the barrel backwards. I know the winders used to confuse me too but that don't take much. | |||
another butcher/shoemaker/blacksmith work! | ||||
