Closed Topic Closed
Waltham Model 1908 Grade 620. "Click" to Login or Register
Serial number: 22688049.
Hi folks. I have completely stripped the movement, cleaned and oiled and am in the process of re-assembling but I just cannot work out how the mechanism for winding and setting the hands should look prior to putting the plate on. It's those two bits of metal with a "U" shaped spring. Would there be a picture anywhere?.
Thanks, Steve.
Stephen, you have the famous "evaporating spring" mechanics designed by some alien visiting the Waltham factory to drive the next Century's (1899- now!)watch repair people NUTS! Razz
I will try and post a Pictorial about this part set and this assembly tomorrow. (all my stuff is at the shop.)
That would be brilliant Dave. I have spent about 5 hours so far trying to work the mechanism out to no avail.
There is a long thin metal strip with two raised ends which runs in a groove along side the mechanism and that has left me flumoxed.
Kind regards, Steve.
Administrative Assistant
Picture of Dr. Debbie Irvine
Information has been posted now in a separate topic.
CLICK HERE: Assembly of Waltham 16s Pendant wind set parts
Smile
Posts: 5882 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Closed Topic Closed
