Stem fails to engage.
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/876108933
September 17, 2010, 15:29
Stephen John Ward
I have a AWC & Co "Empress" 16s stem wind and set pocket watch case to which I am fitting a Waltham 15 jewel 16s movement ( 22,688,049).
The movement fits like a glove and is held in place in the usual way by two screws.
The mechanism on the watch to wind and set the hands works perfectly and when I pull the crown up it turns the hands like it should BUT when I push the crown back down it fails to engage the winding mechanism.
It seems that it is only just failing to engage and I was wondering if there is any adjustment available to effectively lower the square peg a tiny bit?...
Thanks Steve.
September 17, 2010, 18:47
Buster Beck
Hi Stephen,
We touched on this subject a few days ago, click on this link and see if it will help with the problem;
https://ihc185.infopop.cc/eve/f...86047761/m/178102733
Hope that helps Smile
