Waltham Mainspring. "Click" to Login or Register
posted August 04, 2013 08:55
Hi Folks. I have a 16 size 15 jewel Waltham pocket watch which I have completely rebuilt. I have meticulously cleaned and oiled, but unfortunately the watch is running about 2 minutes every 24 hours slow, even on maximum adjustment. The balance wheel, hairspring look perfect and amplitude seems excellent. Here is my question: Is it possible for the watch to run slow if a stronger than normal mainspring is fitted?, I was thinking about increased amplitude?.
Thanks, Steve.
posted August 04, 2013 17:57
Check to see that the regulator pins aren't too far apart and the hairspring is not bouncing very far between the pins. You may just have to close up the regulator pins a bit and that will speed up the watch. If that doesn't help, assuming all else is good, then the balance vibration needs to be checked.
The short answer to the increased amplitude question is no, increasing amplitude does not slow the watch. Think along the lines of a tuning fork. It always has the same pitch regardless of how strongly it vibrates.
posted August 05, 2013 11:51
Stephen, after you make sure the regulator pins are properly gapped to contain the hairspring without free-play, adjusting 2 minutes a day fast or slow is easy because your 16a Waltham should have at least 1 pair of mean time screws which to speed it up 2 minutes can be adjusted in 1 full turn. If you have a higher end 15J with 2 Pr., you need only adjust each of the 2 pair in 1/2 turn and this should bring your time in closer. if that makes the watch run "too fast", just back them out a bit.
ALWAYS remove the balance cock, mount the Cock/Balance wheel assembly on your watch makers pin, carefully hold the Balance wheel and adjust the M.T. Screws with a timing screw tweezers as pictured below.
Hint, when on the watch makers pin as pictured, adjusting the regulator pins are also very easy.
posted August 05, 2013 16:08
Well guys, I learn something every day!. Thank you Roger and Dave for taking the time to reply and I will remove the balance cock and carefully tweak the screws one full turn inwards. The balance wheel has one of these at each end of the cross shaft.
As you can gather I am no expert but am learning every day.
This is a superb site and I am in gratitude to you both.
Warm regards from the UK.....Steve (wyvillman).
posted August 06, 2013 11:33
As usual, Dave supplies a great graphic for the meantime screw adjustment. Glad your watch has these screws...it makes it a lot easier than going thru the vibration checks and deciding whether to shorten the hairspring or lighten balance screws.
IHC Member 456
posted August 06, 2013 13:56
Stephen, although your comment indicates your watch only has 2 meantime screws at the balance arms, for the future you should know that adjusting meantime screws that are 90 degrees from the arms (on a cut balance wheel as shown above) will affect the temperature compensation and should not be done (assuming they haven't been touched since they left the factory).
Mike
Posts: 541 | Location: Mohrsville, Pennsylvania U.S.A. | Registered: February 15, 2005
posted August 06, 2013 20:55
Michael makes in interesting point as Hamilton's Mean time screw adjustment chart refers us to all 4 screws when timing watches. There has been much discussion about those "mid" screws along with the importance of understanding consistency of "Rate" error as opposed to "Daily Deviation" . . .
posted August 07, 2013 07:29
Thank you all very much indeed. I have today succeeded in regulating the watch, but it took two goes. I ended up having to turn the meantime screws two full turns (720 degrees) and now she is running beautifully with the micro adjuster in the middle.
I will carry the watch around with me over the next few days and see if any small adjustment is required...........top site, top people.
Thanks so much......Steve.
posted August 07, 2013 09:10
The finished watch!!
posted August 07, 2013 09:11
Another pic.
posted August 07, 2013 11:07
Magnificent! The dial and hands present handsomely
posted August 07, 2013 14:08
A top accolade indeed from a top watchman David. I assembled the watch in bits and bobs really and was thinking of giving it to my son who gets married next July. The watch has a new mainspring all greased and ready to go. Steve.
posted August 07, 2013 14:18
One more, with matching blued hands....
posted August 07, 2013 15:21
Very nice Stephen! Glad you were able to get it adjusted nicely.
posted August 07, 2013 15:51
Thanks Roger.....
