Lever Set Movement in a Hunter Case "Click" to Login or Register
Hi Folks
Is the above a legitimate combination? Would it have been factory made or have been done by some watchmaker / repairman or whoever to overcome some problem?
I have seen it on a 21J Elgin of 1911 vintage.
Your comments please.
Gordon
Posts: 184 | Location: Christchurch, New Zealand | Registered: February 02, 2007
Gordon
'hunter' or 'open face' and the setting mechanism of a watch are independent.
open face movement - winding stem at 12 o' clock
hunter movement - winding stem at 3
( winding stem can be replaced by pendent on the older kw/ks)
In the time when the winding stem came out all watches were lever set or pin(needle) set (the european ones).
Setting by stem (push- pull crown) was the latest improvement of the setting mechanism.
In the early times of american watchmaking a lot of movements and cases were sold separate and put together by the jeweler/watchmaker.
If your combination is right can be decided when we check the files with the serial number of the movement.
Only 'wrong' combination is the so called 'sidewinder' which is a hunter movement in an open face case.
Please give us the serial number of the movement
Gerald
Gerald
The s/n is: 16677770.
Gordon
Site Moderator
Picture of Tom Brown
Gordon
According to the database that serial number would be a hunter movement lever set, also not a lot of those made.
http://elginwatches.org/cgi-bi...677770&action=search
Hi Tom
Thanks for the info.
Gordon
Elgin made more than it's fair share of Hunter cased lever set movements, grades 149 and 348 and the 373 are just a few. I also have a FT grade 373 and the oddity about it is that most hunter cased lever sets don't have the lever at the 2 position like most open face watches but at the lower position. I think for whatever reason Elgin wanted to maintain the lever position of the open face types but setting the grade 373 is a bit akward because when you pull the lever rather than pulling up and out you are pulling the lever out and down. I will post some pictures of mine and yes they did not make many another low production Elgin but a beautiful watch. Below are some pictures of the Father Time grade 373, the setting lever is at the 9 min position rather than the typical 6 min position of the open face and not like other hunters where the set lever is closer to 5 hour area. It also has the Bunn Special type ray pattern which you also see on the 18 size Elgin grade 367 and a truncated ray pattern found on my Elgin 23j Veritas grade 453 shown also.
