Question - Measuring Watch Cases "Click" to Login or Register
Picture of Sheila Gilbert
Can someone tell me how to measure a watch case to figure what size watch it holds?
From the front? the back? on the rim? inside it?
I have a few that I would like to get some of my watches in, and have no idea what size they actually are.
Thank you!
Sheila
Sheila,
Not sure how everyone else does it here but I always measure the inside diameter under the bezel. So take the bezel off and see what size movement you can fit in there. When I sell movements on eBay I always measure the diameter dial side.
Samuel
Posts: 115 | Location: Jamestown, New York in the USA | Registered: August 12, 2008
Samuel,
Thank you!
That is what I thought, because I knew that the dial side is usually larger than the movement side, but wanted to be sure.
I have also read in here, that you can't count on everything being equal, so if I run into more questions, I will come back in.
I also need a lesson about cases and the space for a lever set movement, and some of the glitches that go with them.
Now I can get to measuring. Thanks again.
Sheila
Honestly I think measuring watches or cases is the most annoying part of selling them online. Too many variables between sizes. If I call a watch a 16 size it could be off by 1-2mm. Rare but does happen. I posted awhile back about an 8 size movement from Elgin that was the exact same model and plate pattern of a 6 size and PWATCH shows it as a 6. So I get people emailing me telling me I must be wrong. But the absolute worst is when I post the exact measurements in MM and I get emails telling me to please put it in Inches!!! I always reply back with the measurement in inches but what I really want to do is tell them to turn their ruler over it probably has MM on it!!!
Samuel
