What Elgin Model is This???!!! "Click" to Login or Register
A BWR very early 15J adjusted (RR??) Model 1 loooking movement, but with Stem wind Lever Set mechanics, but the barrel cover still machined for a Key wind.
The neatest Planetary gear setting mechanism I have ever seen and the Barrel cover and Pillar Plate Serial numbers match. I have some top wheels that would work on this, but need a lever. Anybody seen one of these things before?
Picture of Brian C.
Hi Dave,
The serial number comes back as a model 2, grade 70. I looked the set lever up in my parts book and it says the part number is 48. I have a nos part #48 but it doesn't match yours. If I remember right, about ten years ago I ran into this type of movement and I believe they called it a ring gear movement, but I not sure. It's an interesting movement.
I'll check my parts movements and see if I have anything.
Brian C.
Very interesting David, I've not seen one like it before.
And thank you Brian for your generosity, I don't know what we'd do without you!
In a movement such as the one shown which appears to be somewhat uncommon. How do you go about determining which are original parts and which are parts that have been fabricated to remedy a problem?
John
The answer to that is "only God Knows"! (Or Maybe we can get Lindell to jump in his time machine and go ask Elgin in about 1876. Cool )
I have the part you need on a parts movement. It isn't perfect but it can be yours. How does 5.00 donation to IHC 185 sound? Email me your address.
Aaron
Aaron, I have yor e-mail too, and we will get this done. If this is what I hope it is, I will donate at least that to 185.
