Please help with acronym watch condition at Jones & HoranGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
hello all, I was looking at the Jones and Horan site. Can't figure out what the reference to "many/some MFS" is in the condition report. It has to be simple but I give up, I just draw a blank. Thanks in advance. Regards Rick | |||
Micro-fine scratches, Rick. kh | ||||
Many thanks Ken. I had thought of fine scratches,my thought "many/some Multiple Fine Scratches" was redundant for sure. Micro never entered my mind. Now I can sleep. thanks agaib Regards Rick | ||||
here all aronyms from J&H : “AMAC” = anti-magnetic auto-compensating | “AN” = Arabic numeral | “cal” = caliber | “ct” = carat weight | “DES” = diamond endstone | “DR” = double roller | “DSD” = double sunk dial | “dwt” = pennyweight (20 per ounce troy) | “ED” = enamel dial | “ET” = engine turned | “FS” = fine scratch(es) | “g” = gram (31.1 per troy ounce) | “GF” = gold-filled | “GJS” = gold jewel setting(s) | “GP” = gold-plated | “GRO” = good running order | “H” = height | “HB” = hinged-back | “HB&B” = hinged-back & bezel | “HC” = hunting-case | “hl” = hairline(s) | “HS” = hairspring | “J” = jewel(s) | “K” = karat of gold quality | “KW” = key-wind | “KS” = key-set | “L” = length | “LS” = lever set | “M” = model | “MB” = motor barrel | “MFS” = micro fine scratch(es) | “mm” = millimeter | “MOP” = mother-of-pearl | “mvt” = movement | “NI” = nickel or other white plating | “NOS” = new old stock | “NR” = not running | “OF” = open face | “OH” = overhaul | “p” = page | “PG” = pink gold | “PW” = pocket watch | “QS” = quick set | “QSD” = quadruple-sunk dial | “ref” = reference | “RG” = rose gold | “RGF” = rose gold-filled | “RGP” = rolled gold plate | “RN” = Roman numeral | “RPBM” = rhodium-plated base metal | “RR” = railroad | “S” = size | “s#” = serial number | “SB” = screwed-back | “SB&B” = screwed-back & bezel | “SO” = swingout | “SS” = stem-set (pendant-set) | “SSD” = single-sunk dial | “SW” = stem wind | “TP” = Total Production | “TSD” = triple-sunk dial | “TW” = total weight | “UFS” = ultra fine scratch(es), brushing | “W” = width | “WED” = white enamel dial | “WG” = white gold | “WI” = wind indicator | “WR” = water resistant | “WW” = wrist watch | “YG” = yellow gold | ||||
Peter, how thoughtful of you. Thank you for the courtesy. "RPBM" would have made me suicidal trying to figure out that one. Have already printed the list. Regards Rick | ||||
