Hi All, Has anybody had this happen to them . I demagnetized a tweezer (tips), only to find that the opposite end became magnetized. It was not magnetized before (I Think). although it it not something I check. Mel
Posts: 507 | Location: West Newton, Massachusetts USA | Registered: September 10, 2006
If your Demag is a flat-top, was the other end of the tweezer off the edge?
If it was a toroidal type (better, I think) did you prematurely let off the switch before moving the tweezer completely away (more than 12") from the coil?
My damage is a flat top. I usually hold the tip perpendicular to the top and move away perpendicular to the top of the demagnetized until I am 6 or 7 inches away. Should I do each end separately? I guess the handle first ending with the tips next. But how about the middle? Mel
