I FINALLY FOUND IT! "Click" to Login or Register
IHC Member 1610
I finally found it. I'm sure each and every one of you have a similar story.
About two months ago I was putting some size 16 hands on a movement when my hand slipped and PING I heard the minute had bounce off a wall, a box or something in my immediate vicinity. Well I must have search a hour and found nothing. One thing I have learned is not to go moving things around because you may make matters worse.
So after not finding it I decided well I might as well start moving things around and see if maybe the hand fell between something. So after carefully moving one thing at a time and then replacing it before I moved something else I still did not find that hand.
So now I decide to use a magnet (oh and by the way the room is carpeted), I found a lot of tiny watch parts I did not know I was missing or I had dropped. Luckily I did not need any of them but still no minute hand.
I decided to quit looking for it. One thing I have learned is sooner or later it will show up. Well a couple of nights ago it showed up. No where near the area I lost it in or heard it hit. It was 10 or 12 feet away in a direction I never thought it would have gone. The only thing I can think of is after it hit whatever it hit it must have change direction and kept right on going. I never dreamed it had enough power to go as far as it did.
My watch shop is in my basement. I painted the concrete floor satin white using that Drylock stuff. It makes finding parts a whole lot easier.
IHC Member 1610
Sounds like the voice of experience.
IHC Member 1541
Picture of Lorne Wasylishen
Good for you Harry.
When just beginning in this hobby and doing stuff in the kitchen, I lost a minute hand as you did. A week later I found it on top of the refrigerator.
I have never had the luck of finding something lost that wasn't right near the bench. I think the parts fall into an alternate universe or something.
IHC Vice President
Pitfalls Moderator
I've found hands by searching the vacuum cleaner dust with one of those super-strong neodymium magnets.
IHC Member 1335
Picture of Tom Brunton
I think you will find that a spring cable handled magnet such as mine is as good a tool as you can find for locating lost screws,the handle is curled for purposes of the photo, and they are very reasonably priced,best wishes, Tom
I have had a similar situation.
My deduction on my case was that it richoched off the (?) and landed on my clothes somewhere.
When I left the workbench it fell off where ever I found it.
I am sure others have similar stories, and maybe other analysis.
Posts: 507 | Location: West Newton, Massachusetts USA | Registered: September 10, 2006
Yesterday, a seconds hand fell out of my hair. But usually these evaporating parts go somewhere they can see you but you cannot see them til they are ready! (Like my Cat!)
I have three size "searching" devices, the 6-1/2" diameter Alternator magnet from my 97 Harley which the factory forgot to balance, a "pickup magnet ($5.00?) from Harbor freight and a magnetic screwdriver I used to Give away when I was in the R/C business. If these tools miss finding the part, it is;
1. Non-Magnetic . . .
2. Sitting on my work surface hiding under something . . .
3. In another dimension of time and space and will return eventually.
Picture of Dan Carter
I have had this happen too. I usually lose roller table jewels or the last screw of a certain kind that I have in my inventory. I lost one not too long ago while working on a sheet. I figured if it dropped, it would not fall far, and I could lift the whole sheet up and let the screw roll to an end if I lost it ... not the case. Losing one of these parts usually enables me to release a long-pentup four letter word that usually signifies the end to the watch repairing event for the day.
In an earlier post, it was mentioned that some folks use a camera tent to work on parts that are at risk for flight from flying to far. I have not set up my work area like that yet, but will soon. I also like the white carpet / paint idea. The hardships of being a watchmaker / enthusiast ...
Dan
When I was doing model airplanes, I visualized putting my whole work area on a grid over a giant Bowl with a small hole in the bottom of the bowl where the lost parts rolled out into a jar.
IHC Member 1369
I had a big grin on my face all the way down reading these posts. Yep, been there lost that!
In my case I also work on plastic models - not planes but HO scale railway things - and once those plastic bits go 'ping', well, I am sure there is an alternate universe with tiny bits of plastic getting in everyones way. Smile
Posts: 542 | Location: Ontario in Canada | Registered: February 10, 2010
IHC Member 163
Picture of Mark Cross
That could explain why a lot of long time watchmakers move up to clock repair. The parts are bigger and easier to find when dropped. Wink
Regards! Mark
Picture of Gary Dutton
I have a 14inch magnetic bar mounted on a broom handle and wheels on each end of the magnet and I move slowly over the floor until it picks up the offending item.
Cheers
Gary
Posts: 341 | Location: Brisbane, Queensland, Australia | Registered: September 10, 2009
