I finally found it. I'm sure each and every one of you have a similar story.
About two months ago I was putting some size 16 hands on a movement when my hand slipped and PING I heard the minute had bounce off a wall, a box or something in my immediate vicinity. Well I must have search a hour and found nothing. One thing I have learned is not to go moving things around because you may make matters worse.
So after not finding it I decided well I might as well start moving things around and see if maybe the hand fell between something. So after carefully moving one thing at a time and then replacing it before I moved something else I still did not find that hand.
So now I decide to use a magnet (oh and by the way the room is carpeted), I found a lot of tiny watch parts I did not know I was missing or I had dropped. Luckily I did not need any of them but still no minute hand.
I decided to quit looking for it. One thing I have learned is sooner or later it will show up. Well a couple of nights ago it showed up. No where near the area I lost it in or heard it hit. It was 10 or 12 feet away in a direction I never thought it would have gone. The only thing I can think of is after it hit whatever it hit it must have change direction and kept right on going. I never dreamed it had enough power to go as far as it did.
Posts: 3858 | Location: Georgia in the USA | Registered: September 22, 2011
I think you will find that a spring cable handled magnet such as mine is as good a tool as you can find for locating lost screws,the handle is curled for purposes of the photo, and they are very reasonably priced,best wishes, Tom
Posts: 1746 | Location: Aylmer, Ontario in Canada | Registered: December 15, 2009
I have had a similar situation. My deduction on my case was that it richoched off the (?) and landed on my clothes somewhere. When I left the workbench it fell off where ever I found it. I am sure others have similar stories, and maybe other analysis.
Posts: 509 | Location: West Newton, Massachusetts USA | Registered: September 10, 2006
Yesterday, a seconds hand fell out of my hair. But usually these evaporating parts go somewhere they can see you but you cannot see them til they are ready! (Like my Cat!)
I have three size "searching" devices, the 6-1/2" diameter Alternator magnet from my 97 Harley which the factory forgot to balance, a "pickup magnet ($5.00?) from Harbor freight and a magnetic screwdriver I used to Give away when I was in the R/C business. If these tools miss finding the part, it is; 1. Non-Magnetic . . . 2. Sitting on my work surface hiding under something . . . 3. In another dimension of time and space and will return eventually.
I have had this happen too. I usually lose roller table jewels or the last screw of a certain kind that I have in my inventory. I lost one not too long ago while working on a sheet. I figured if it dropped, it would not fall far, and I could lift the whole sheet up and let the screw roll to an end if I lost it ... not the case. Losing one of these parts usually enables me to release a long-pentup four letter word that usually signifies the end to the watch repairing event for the day.
In an earlier post, it was mentioned that some folks use a camera tent to work on parts that are at risk for flight from flying to far. I have not set up my work area like that yet, but will soon. I also like the white carpet / paint idea. The hardships of being a watchmaker / enthusiast ...
Dan
Posts: 407 | Location: Northern Virginia in the USA | Registered: October 08, 2011
When I was doing model airplanes, I visualized putting my whole work area on a grid over a giant Bowl with a small hole in the bottom of the bowl where the lost parts rolled out into a jar.
I had a big grin on my face all the way down reading these posts. Yep, been there lost that!
In my case I also work on plastic models - not planes but HO scale railway things - and once those plastic bits go 'ping', well, I am sure there is an alternate universe with tiny bits of plastic getting in everyones way.
Posts: 542 | Location: Ontario in Canada | Registered: February 10, 2010
I have a 14inch magnetic bar mounted on a broom handle and wheels on each end of the magnet and I move slowly over the floor until it picks up the offending item. Cheers Gary
Posts: 341 | Location: Brisbane, Queensland, Australia | Registered: September 10, 2009
