IHC Life Member |
Samuel posting under Johns name.....(gotta remember my own password soon) OK is this a defective case or was there a special movement made by Waltham that needed this? The bezel and "hinged" back are on the wrong sides!!!! Normally when you put the movement in the bottom or movement side is smaller than the top or dial side and has a lip to tighten the screws onto. This case is reversed. So the lip to tighten the movement "Case" screws onto is on the front bezel side?!? Any one here got any ideas? ![]() | ||
Hi Sam, We re-sent your registration details. ![]() My first impression is someone may have improperly modified this case in a lathe, unlikely but that could help explain the odd appearance. Anyhow, somehow the case at one time functioned because there is wear on it! Could it have actually been designed to "show-off" the movement and the user rarely checked the time? Perhaps putting movement in the case ![]() Lindell ![]() | |||
IHC Life Member |
(Sam again) I'll check for the account info later tonight. I have a 12 size movement I just put on ebay I'll put into it and see how it looks. I'll post pictures in a few minutes. Samuel | |||
IHC Life Member |
well a 12 size movement doesn't quite fit....maybe a 14 size? ![]() | |||
IHC Life Member![]() |
The only thing I can think of is the Waltham "Opera" watch which has a 1.505" diameter body while BOTH the dial and the back trim ring are 1.520 O.D. So the watch is held central in the case from both sides when the smaller movement with dial assembled is inserted into the case and then the back ornate trim ring is screwed into place by attachment of the 3 ring mounting screws just outside of the small movement. Check the I.D. of the case and see if it is 1.505" ![]() | |||
David I don't have a micrometer nearby with inches on it so I have to use millimeters and convert. The inside diameter is 39mm and using online conversion tools 39 millimeter = 1.535 433 070 9 inch [international, U.S.]. | ||||
Looks like David may have figured it out! With all the gold cases being lost to scrapping these days, despite some obvious wear this otherwise ordinary looking gold-filled case should be identified and therefore saved. If this one is indeed what David suspects a worthwhile Waltham Opera Watch could once again be complete. ![]() | |||
Sam, I would like to try it on for size. E-mail e at david@glopar.com if you think we cna set something up. | |||
I believe this case is for a Marsh's patent. I'll see if I can post some scans of mine. It's a 25 year Wadsworth case. ![]() | |||
Number 2 ![]() | |||
Note in picture 2, the watch isn't even signed. #3 ![]() | |||
My watch measures a 10s. Note the ring it has. ![]() | |||
Say, this is really getting interesting! ![]() | |||
Very interesting! David we can set up something soon. Brian can you show some pictures of your case without the movement in it? Samuel | ||||
Samual, Sorry I can't do that. The watch is in the bank. Brian C. | |||
