Keystone 18 size question about dust proof models with cover?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Viewing the other Keystones on this site it appears that all the dust proof models have a cover by the bal.cock.Should all dust proof models have this cover? The one I have s/n 417761,15 jewels does not and there appears as if there never was one on this watch.Just curious. Regards Roger ![]() | |||
Close up of Bal. cock ![]() | ||||
Dial ![]() | ||||
Roger, Compare your watch (which is marked "Pat. Dust Proof") to the dustproof (pic below) that passed through my collection. Your plate cuts are different around the area where windowed part attaches to the dial plate. The marking says it should have a cover and if so it may be a variant in the cover plate cutout. Also it looks like yours needs the regulator arm tension spring. | |||
Thanks David.I see what you are talking about but I do not see how it would be attached as there is no hole in the base for the screw for holding it on. Such as yours. Roger | ||||
Look for a hole in the dial plate sort of between the Pallet fork bridge jewel area and the Dial plate O.D.. That is the hole that the big blue (on my example) screw passes through the dust proof cover and attaches it to the dial plate. | |||
David,absolutely nothing there.Oh well,doesn't effect the running. Roger | ||||
