Is there an advantage to storing pocket watches vertically? I keep mine in a machinist's chest. The shallow drawers each hold about 24 watches lying flat in the dial up position. Opening the drawers, I can look over my collection. To me, the dial is the most interesting part of the watch (without opening the back).
Posts: 149 | Location: Southern California in the USA | Registered: September 23, 2009
Any craft store should have thick foam. You could easily slice into it and stand watches in the slots. Cheap and simple Tom. My wife goes often, I will see what I find.
Posts: 5101 | Location: Buffalo, New York in the USA | Registered: November 11, 2009
Chris: I'm looking for this so I can fit the watches in a safe. The display boxes I have are too large for the safe as is the briefcase storage case I have.
Posts: 496 | Location: Wisconsin in the USA | Registered: March 10, 2012
Thomas, there is a very specific reason that we DO NOT store pocket watches vertically. That is because IF you drop them, the shearing shock of the "sudden stop" is about 10 times more likely to break the balance staff. An expensive and sometimes life-ending issue with these precision pieces under our care.
I use the snap cases like you mentioned here and they work great. I do however put 2 cotton handkerchiefs in the bottom and overlap them to cover the top of the watches to keep them more snug and to also reduce the amount of scratching from the plastic / felt sprayed inserts. I like them stored on their back so that I can easily see what I have and can also get to them easier. Dan
Posts: 407 | Location: Northern Virginia in the USA | Registered: October 08, 2011
Jon, I have similar cases to your bottom photo. I bought 2 on Amazon. The 3rd was a gift form my wife. Unfortunately, they don't fit in my safe. Looks like the cases from Desmond will.
Thomas, i use stackable plastic trays with drop in inserts in my safe, each holds 6-12 watches depending on the insert used and they are made to stack on top of each other. I purchased a bunch of them years ago in the jewelry district in Los Angeles. I think i still have a bunch left, they measure 14 3/4 x 8 1/2 x 1 and are black plastic. I will pull them out tomorrow and post a picture if you're interested. I would have to figure the shipping cost for you.
Posts: 1501 | Location: Rancho Cucamonga, California USA | Registered: December 20, 2006
