Hairspring replacement. "Click" to Login or Register
posted August 26, 2011 01:08
Hi. Basically, how are hairsprings measured?.
I need to change the one in the picture as it is distorted and beating too fast.
I understand about mainspring measurement but how about hairsprings?.
posted September 04, 2011 17:49
100 views and no replies.........?
posted September 04, 2011 18:03
The post is in the pocket watch section, perhaps it would do better in clocks.
Picture of Eugene Buffard
posted September 04, 2011 21:10
Hairsprings are vibrated to fit each different watch / clock escapement. Does this one have a over coil. Unless you are an experienced watchmaker. It would be nearly impossible to replace your self.
Posts: 3326 | Location: Illinois in the USA | Registered: July 06, 2010
posted September 04, 2011 21:12
The one on your clock escapement most likely can be straightened.
posted September 05, 2011 09:33
If it is not mangled ie. "kinked" then certainly untangling it is preferred to replacing it. I have found good luck using #5 and #7 curved tweezers close the door to the shop and take your time. What ever you choose to do with it "good luck"
Regards, John
posted September 05, 2011 13:12
Stephen, Two things;
First your movement looks like a "Carraige" type that was assembled to a larger non-carraige" type clock dial.
Second, a replacement hairspring for that movement qualifies as an "un-obtanium" grade part . . . meaning as it is still running, straightening the damaged spring is a far better and most practical "fix".
Our own hairspring master, Chris Abell could probably be persuaded to take on that task.
posted September 06, 2011 16:08
You can also check Timesavers who sell a varietyof complete replacement platform escapements like yours.
http://www.clock-parts.com/cat...Level=2&ProdID=23105
posted September 12, 2011 00:36
Thanks everyone for taking the time and trouble to reply.
