Hi. Basically, how are hairsprings measured?. I need to change the one in the picture as it is distorted and beating too fast. I understand about mainspring measurement but how about hairsprings?.
Posts: 189 | Location: Kent in the United Kingdom | Registered: May 27, 2010
Hairsprings are vibrated to fit each different watch / clock escapement. Does this one have a over coil. Unless you are an experienced watchmaker. It would be nearly impossible to replace your self.
Posts: 3327 | Location: Illinois in the USA | Registered: July 06, 2010
If it is not mangled ie. "kinked" then certainly untangling it is preferred to replacing it. I have found good luck using #5 and #7 curved tweezers close the door to the shop and take your time. What ever you choose to do with it "good luck" Regards, John
Posts: 299 | Location: Mount Brydges, Ontario, Canada | Registered: November 10, 2005
First your movement looks like a "Carraige" type that was assembled to a larger non-carraige" type clock dial.
Second, a replacement hairspring for that movement qualifies as an "un-obtanium" grade part . . . meaning as it is still running, straightening the damaged spring is a far better and most practical "fix".
Our own hairspring master, Chris Abell could probably be persuaded to take on that task.
