Gene, you have an absolutely fascinating watch! Notwithstanding the condition, and the signed 14K case, this watch has a number of "extra" novelties of it's own; (I brightened up your pic a little to help this . . .)
1. It is in direct sequence of a run of "John C. Deuber Special" movements all marked "Adjusted Heat and Cold", which is hardly wnat one would consider "Railroad" grade.
2. Yet it is signed "M J * * Railroad Watch"
3. The 700,000 serial number places it at 1890 which is when the Hampden first began actual production in Canton and the watches produced were still thought to be using many "old" Springfield factory parts.
4. The fact that Mermod amd Jaccard (The Midwest equivalent of Tiffany's) was persuaded to sell a "Fake" RR watch is testimony to the persuasive talents of Mr. J.C.Deuber at that time.
An incredible piece and worth more research.
I don't think Hampden started pushing the 17j 18s until 1891 I would think a 15j adjusted to Heat/Cold/Iso would have been ok for most if not all railroad companies. Adjusted to heat/cold/iso, patent regulator, 15j, hunter, open, pendant, lever would have worked unless someone can show otherwise.
This was the standard from the Jeweler's Circular as late as Sept 1891
A.H. Murphy, the jeweler, has been appointed inspector for Erie Railroad of the watches to be carried by all engineers, firemen, conductors, brakemen and yardmasters employed by the Lake Shore road. Each employe must own and carry a watch with not less than fifteen jewels, patent regulator, adjusted to heat and cold, and subject to inspection at least once in two weeks by Mr. Murphy.
Posts: 1797 | Location: Michigan in the USA | Registered: September 19, 2009
Gene that is a dandy watch and as a Hampden collector I am envious. On second thought it is probably a Swiss fake and you should sell it to me for $25. JUST KIDDING! But if you want to sell it keep me in mind and thanks for the pictures.
Deacon
Posts: 1004 | Location: Omaha, Nebraska in the USA | Registered: February 14, 2009
As for as scarce. I have know idea. I own three how scarce can they be.
The book lists them as 2 stars.
I have seen one other in bad condition on eBay about 4 years ago. It need a lot of work. I did not win. and it was most likely a good thing I did not win.
Does anyone else have a M.J. Co Railroad Watch
Posts: 3328 | Location: Illinois in the USA | Registered: July 06, 2010
Gene, maybe you have the last three ever . . . As far as RR greade, Claude pretty much hit the nail on the head, when it passed inspection it was RR. (Psst. Do not BREATHE A WORD TO any of the RR grade "authorities" that H & C adj was OK for {some} RR's!)
Gene, the fun thing would be to see how close it could be brought to RR time with a service and some TLC . . . Though I expect Messrs. M & J Co. may have been more likely to sell one to a lucky Riverboat Gambler or some Saint Louie beer guy named "Busch".
