Elgin 18s Kw Model 1 mainspring.Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1610 |
Elgin 18s Kw Model 1 mainspring. It might be on here but if it is I can not find it. I am looking for for which mainspring the 18s Elgin KW model 1 and model 2 take. I know what it looks like it is a touge mainspring but I can not find the number so I can try to find one. Thanks, Harry | ||
| IHC Member 1555 |
The correct spring for those Harry is like the proverbial "hen's teeth" to find. Most of the newer parts books don't have it listed, the original Elgin part number is #2324, I think C. E. Marshall listings have the original factory number as #2325 which is incorrect. A lot of so called repairers end up drilling the mainspring barrel and lid to fit a tee-end, not a great idea, but in time to come you will probably have no option, unless someone starts making a larger selection of new mainsprings to sell. Send me a private email when you get a chance mate and I will probably be able to shed some more light on it for you. Also if you can post a pic of the barrel pin (should be a round steel pin protruding into the barrel) the spring catches on as well please, that would be great. | |||
| IHC Member 1610 |
Hi Bila, Thanks. It is 3am and I am going to bed but since your 16 hours ahead and I will take the watch apart and send you the pictures. But in the meantime the C.E. Marshall 2325 spring should work because it is really a 2324 is that correct. Right now it has a white alloy mainspring that someone bent the end over and slid a short piece of mainspring in it so it would catch. That made me think I have several key winds and all have usable mainsprings but I am going to need one sooner or later so I am being proactive. When you get up tomorrow you should have an email from me. Thanks mate, Harry | |||
| IHC Member 1613 |
Gary, Do you know the measurements on that spring... | |||
| IHC Member 1610 |
Hi Gary, According to "American Mainsprings" It is 2.92x.229x22.5 . It has a tongue end. It is also pencilled in that I can use a Waltham 2203 but I would then have to drill a hole into the barrel to accept the "T" end. Harry | |||
| IHC Member 1555 |
Just sent you an email Harry | |||
| IHC Member 1610 |
Thanks Mate! | |||
| IHC Member 1555 |
Just sent you another email Harry with the info you need | |||
| IHC Member 1610 |
Thanks Mate! | |||
