I purchased an Elgin military timer in the auction section of this site from Tom Brunton last May. When I received it, the first thing I noticed was that it left a small puddle of oil wherever I left it. This past week I took it apart to clean and oil it (properly), it was the first chronograph I took apart so when I put it back together and it actually worked, I was very happy and relieved. I take digital photos of the watches I work on to aid me in their re-assembly so I will show the progress here. First, notice the oil, not heavy oil but gobs of dripping oil | |||
This was under the ratchet and crown wheels | ||||
more oil ![]() | ||||
4 | ||||
Look at the puddle on top of the mainspring barrel | ||||
The dial side wasn't as bad | ||||
Back together and running perfectly, with that tiny balance wheel it has quite a beat. | ||||
The dial shows some bubbles, I'm thinking it may have been from the excessive oil. Now, where do I find some hands ?. There were no hands on this when I purchased it. | ||||
IHC Life Member |
Wow talk about excess oil there is enought there to lube hundreds of watches. Hey Ray I remember seeing a NOS dial like this I will see if I can find it for you, give me a couple days. | |||
Thanks Rob | ||||
IHC Life Member |
Opps sorry Ray I found the ones I was thinking of they are not the same. I will still keep an eye out for one though. | |||
IHC Member 1555 |
Rob, sorry to but in on your discussion with Ray, but I was wondering if you would like to sell some of those dials, 2 off the Black & 2 off the white, depending on price? Best Regards, Bila | |||
Those are some nice dials Rob. Is there anything you don't have ![]() | ||||
Hi Ray, It looks like your timer was only down about a 1/2 quart of oil. ![]() | |||
Brian, That's a possibility since they probably had plastic crystals from the factory. They sure used a heavy brass dial plate for the dial though. | ||||
Ray I thought maybe I had a dial you could use both the two I have look just like yours. Can't find any hands. | |||
